Ford 5095 - 4WD GMC axle bushing.
Does anyone know the size of the Axle/Main-Shaft Bushing for a 1972 Tractor ? I have a serious leakage and need to repair this immediately. Any part-number or Bushing make-size known ?
valmet6400power
@ford5000 or @RPcounty will tell you!
5095SuperMajor
Ok looking forward to answers on my querry
RPCounty
@5095SuperMajor what do you exactly mean with the mainshaft? Do you mean the bush which is pressed in the swivelhousing to support the drive shaft? I have these in stock.
ford5000
@RPCounty The right man in the right place at the right time!
old man jose
@ford5000
WWWWWright amn (lol)
5095SuperMajor
I believe what i call bushing is called in dutch keerring. @RPCounty the shaft i call main comes from the gearbox to the frontaxle. The bushing is held in a casing that is bolted to the axle with 4 bolts
valmet6400power
@5095SuperMajor
If you want to mention an user on this site you can click on the "yellow balloon" next to their name. Then they will get a notification 😄
@RPcounty see above
Ps: it is indeed a "keerring"
RPCounty
@5095SuperMajor so you mean the seal from the inputshaft. This is mounted in a holder which is bolted with 6 bolts to the diff.housing. i think i have these in stock including the gasket with 6 boltholes.
5095SuperMajor
@RPCounty Ok. THANK YOU very much. The new year begins good. How can I get in touch with you? Where are you located? THANK YOU for leaving your details and all the best for 2015
Heb jij ervaring met de Ford 5095 ? Dan kunnen we jouw hulp goed gebruiken! Of je nu actief bijdraagt door foto's, video's, topics, technische gegevens of reacties te plaatsen, of je zorgt er middels de stemknoppen voor dat de beste inhoud naar boven borrelt.. Iedereen kan helpen om dit tot de meest fantastische fan-site te maken die er is. Lid worden is heel eenvoudig!
