John Deere 6010 - 16/16 syncroplus is dat wat
Heb jij ervaring met de John Deere 6010 en hebben de trefwoorden accu en diesel geen geheimen voor jou ? Dan kunnen we jouw hulp goed gebruiken! Of je nu actief bijdraagt door foto's, video's, topics, technische gegevens of reacties te plaatsen, of je zorgt er middels de stemknoppen voor dat de beste inhoud naar boven borrelt.. Iedereen kan helpen om dit tot de meest fantastische fan-site te maken die er is. Lid worden is heel eenvoudig!
The 6030 and 7030 Series Tractor has many transmission options to suit different applications and operations. The SyncroPlus is a fully-synchronized transmission with 12 forward and four reverse gears or an optional 16 forward and 16 reverse gears with electronic reverser for cab models. The fully-synchronized transmission allows the operator to shift between speeds and ranges while the tractor is still moving by engaging the clutch, selecting a different range or speed, and releasing the clutch. The transmission is very easy to engage and select new gear. The spacing between ranges has an overlap for a variety of applications, such as, cutting or baling hay, mowing, loader work, and many specialty applications. SyncroPlus includes direct shuttle shifting from forward to reverse for efficient loader operation and integrated park for simplified operation.
SyncroPlus 16/16 with mechanical power reverser
The SyncroPlus power reverser has 16 forward and 16 reverse gears. This transmission option utilizes four fully-synchronized ranges and four fully-synchronized gears (within each range) for a total of 16 forward and 16 reverse speeds.
SyncroPlus speed charts
For ease of use in loader operations or other applications where frequent shuttle (directional) shifts are needed, the SyncroPlus 16/16 provides an electronic power reverser.
Bron:
salesmanual.deere.com/sales/salesmanual/…
