Fendt 920 - Wont start, need help !
So the 920 wont start, when I turn on the ignition nothing happens, if i turn it on and of a couple of times sometimes it light up. But when i turn the key all the way it goes black again. Seems like there is a bad connection or something? Are there any know problems? Both of the batteries are 3 years old and when i measured the power on them both had 12,9V. The start relay is also 3 years old and had no moist or water inside and looked as it did when it was new. I should mention that this happend after i had washed the tractor, but there was no unusual wash. It was only on the outside panels and the rims.
Could it be the ignition lock?
Hope there are someone who can help me!
Regard Erik
Heb jij ervaring met de Fendt 920 en hebben de trefwoorden fendt , favorit en 920 geen geheimen voor jou ? Dan kunnen we jouw hulp goed gebruiken! Of je nu actief bijdraagt door foto's, video's, topics, technische gegevens of reacties te plaatsen, of je zorgt er middels de stemknoppen voor dat de beste inhoud naar boven borrelt.. Iedereen kan helpen om dit tot de meest fantastische fan-site te maken die er is. Lid worden is heel eenvoudig!
There's a 1 pole connector , in that bad contact by tray corrosion.
That is , the main current supply for the cab.
(Sorry for the bad englisch google translate)
is the starter not 24 volts? i know from the newer models that they have a 24volt starter and 2 batterys al the stuf on the tractor is 12 volts
Normaly the batterys are paralel connected so you have 12 volts but when you want to start there is one batterys disconnected and reconnect it in serie with a heavy relais to deliver 24 volts for the starter after starting the battery are reconnected paralel
i had the same problem with a 930 and i have a bad battery
